My Cart 0 Item(s)
Shopping Cart is Empty
WAE WBT06 Black
Quick Overview
Perfect for smartphone fans, thanks to Bluetooth® wireless technology. Perfect for PC/Mac® users, thanks to wireless audio proprietary technology. 2 wireless technologies in one unique product.
180W Peak Power.
More details
Availability: In stock
Only 2 left
£129.99
        WAE WBT06 Black
        Move your mouse over image
        More Views
        • WAE WBT06 Black
        • WAE WBT06 Black
        • WAE WBT06 Black
        • WAE WBT06 Black
        • WAE WBT06 Black
        • WAE WBT06 Black
        • WAE WBT06 Black
        • WAE WBT06 Black
        • WAE WBT06 Black
        • Product Description
          Details
          Description
          • Perfect for smartphone fans, thanks to Bluetooth® wireless technology. Perfect for PC/Mac® users, thanks to wireless audio proprietary technology. 2 wireless technologies in one unique product.
          • Plug and Play: for PC/MAC® users who have all their music stored on their computer. Just connect the USB dongle and you’re ready to go!
          • Best-in-class Bluetooth® technology ensures incredible sound quality, plus applications for iOS and AndroidTM allow you to control your speaker and access thousands of Web radio stations.
          • Outstanding design: both modern and ergonomic. The speaker can rotate 15° to each side on its metal base.
          • Designed to meet hi-fi standards. Audiophiles will not be disappointed: sound quality has been at the core of product development, to provide rich loudness, deep bass and exceptional treble. In addition, the integrated DSP always ensures the speaker’s frequency response.
          • Powerful: up to 90 W RMS (180W peak power)
          • One 3.5 mm mini-jack line input for connecting an MP3 player or any other audio device.
          • Thanks to the remote control or the app, you can communicate remotely with your speaker and your devices. The application includes the following features:
            • Control your speaker (volume, audio effects, on/off)
            • Listen to your music and the Web radio stations provided for free within the app
            • Use the equalizer to fine-tune your music
          Technical specifications
          • Bluetooth® 3.0 A2DP
          • Wireless audio 2.4 GHz
          • 10 m range = Bluetooth®
          • 20 m range = Wireless 2.4 GHz
          • RF remote control
          • iOS remote application
          • AndroidTM remote application
          • Frequency response: 20 Hz - 20,000 Hz
          • Power: 90 W RMS
          • 2 tweeters
          • 2 woofers
          • Power supply: 24 V/3.75 A
          • RoHS, CE, FCC, Bluetooth® compliant
          • Speaker dimensions: 204 (D) x 370 (W) x 201 (H) mm
          Installing the audio system
          You are a smartphone user:
          Just switch Bluetooth® on and connect with the speaker, and you’re ready to go.
          Install the WAE app to control your speaker remotely. Turn the volume on your speaker up or down via your smartphone, enable audio effects and pre-defined equalizer settings.
          Enjoy a huge database of Web radio stations, and a cool player to listen to your favorites iTunes playlists.
          Thanks to the device selection icon, you decide where the sound will be played: either on your device, or on the speaker.
          You are a PC/Mac® user:
          The USB dongle connects to any computer (Windows / Mac / Linux) and is automatically detected as a sound card. Simply turn the speaker on, and any music played on the computer will be broadcast to the speaker over the wireless link.
          Sound latency is less than 10 milliseconds, and therefore virtually undetectable by the human ear.
          Choose your WAE - Wireless Audio Experience
          The speaker comes in 2 versions: Black or White.
          Choose your favorite color and discover the Hercules Wireless Audio Experience.
          Designed for audiophiles
          The speaker’s sound quality benefits from Hercules’ extensive audio expertise. The challenge met by Hercules’ R&D team was to create a speaker that could deliver hi-fi quality sound in a compact wireless box.
          Play it loud
          Tweeters, woofers, DSP: Hercules hasn’t left anything out. Everything has been done to deliver the most accurate frequency response for great sound reproduction and minimal distortion.
          Enjoy deep bass even at low volumes, thanks to the equalization and loudness effects.
          You’ll be amazed by the detail and accuracy of the sound in such a compact system!
          The Hercules WAE speaker delivers 90 W of amplification spread out through 4 transducers, for pure sound quality.
          Box contents
          • 1 speaker
          • 1 power adapter
          • 1 User Manual
          • Warranty certificate
          Minimum configuration
          • All OS: Windows, Mac, Linux
          • Bluetooth® enabled devices
          • Application:
            • iOS 4.0 or later
            • AndroidTM 2.2 or later
        • Product Reviews
