My Cart 0 Item(s)
Shopping Cart is Empty
WAE Outdoor 04Plus
Quick Overview
Designed for Riders.
  • IP66 : Water and dust-resistant
  • Shock-resistant
  • ¼” multi-use screw thread
More details
Availability: In stock
£14.99
        WAE Outdoor 04Plus
        Move your mouse over image
        More Views
        • WAE Outdoor 04Plus
        • Product Description
          Details
          Description
          Wireless speaker designed for riders! Perfect for experiencing all of your rides with even more intensity, accompanied by your favorite music. The ideal companion for getting psyched up or training.
          IP66-certified: resists water, and provides total protection against dust, sand and mud.
          Shock-resistant: reinforced rubber end-pieces.
          Clear, very powerful sound for optimal audio rendering in outdoor conditions (in the wind, on the street): single-unit 2.0 speaker + passive decompression driver.
          Bluetooth® 3.0 A2DP wireless technology. Compatible with Bluetooth® devices: telephones and smartphones, tablets, computers (Windows® Vista/7/8, Mac® OS X).
          More than 12 hours of battery life.
          Can be connected to two Bluetooth® audio sources at the same time: switch from one to the other incredibly easily.
          Control buttons: volume + and -, next and previous tracks, pause and play.
          On/off switch and auxiliary line input.
          USB charging cable included. Compatible with 5 V micro-USB chargers.
          Secure hoop for wrist strap.
          Standard-size screw thread for easy mounting (examples: bike mount, tripod, suction cup mount, etc.).
          Custom Android and iOS app for your smartphone.
          Technical specifications
          RMS power: 2 x 2.5 W RMS
          Peak power: 10 W
          Frequency response: 130 Hz - 20,000 Hz
          Speaker dimensions: 61 (H) / 151 (W) / 61 (D) mm
          Weight: 280 g
          Rechargeable 3.7 V 1500 mAh Li-ion (lithium-ion) battery
          Magnetically-shielded system won’t disturb your surroundings
          RoHS compliant product
          Box contents
          Box contents
          -Single-unit IP66 Bluetooth® speaker
          -USB charging cable
          -Wrist strap
          -Warranty certificate
          -User manual
        • Product Reviews
