My Cart 0 Item(s)
Shopping Cart is Empty
WAE Outdoor 04Plus FM
Quick Overview
Wireless Bluetooth Speaker, Waterproof, Dust-, Shock-Resistant, featuring a built-in FM radio.
  • IP67-certified
  • Clear, very prowerful sound
  • Built-in FM Radio
More details
Availability: In stock
£34.99
        Move your mouse over image
        More Views
        • WAE Outdoor 04Plus FM
        • Product Description
          Details
          • IP67-certified: Immersion-, Dust-, sand- and snow-resistant. Shock-resistant: reinforced rubber end-pieces.
          • Clear, very powerful sound for optimal audio rendering in outdoor conditions (in the wind, on the street): single-unit 2.0 speaker + passive decompression driver.
          • Enjoy non-stop music, thanks to the built-in FM radio - even without your smartphone!
          • Standard-size screw thread for easy mounting (bike mount, tripod, suction cup mount, etc.)
          • More than 10 hours of battery life. USB charging cable and wrist strap included. Auxiliary line input
          A wireless speaker crafted with high-level athletes in mind:
          Specially designed to be used outdoors and in extreme conditions
          The new WAE Outdoor 04Plus FM eats all the toughest things you can throw at it for lunch: impacts, asphalt, rain, snow, dust - even mud? Yes please. In fact, it just can’t get enough.
          IP67-certified
          Thanks to its IP67 certification, the WAE Outdoor 04Plus FM is completely immersion-resistant (for up to 30 minutes at a depth of 3.3 feet/1 meter), and is also fully protected against both mud and even the finest dust particles. With its rock-solid design, cushioning rubber end-pieces, protective metal grille and reinforced access hatch for its connectors, the speaker provides excellent resistance against impacts and all kinds of extreme use conditions.
          Mobile and light on its feet
          Featuring a standard-size screw thread, this mobile and versatile speaker easily attaches to any of your favorite mounting accessories: bike mount, suction cup mount, tripod, and more. It’s also extremely lightweight (weighing in at just 0.66 pounds/300 grams), allowing you to bring it anywhere without a second thought.
          Powerful, stunning sound optimized for outdoor conditions
          Despite its compact size designed to accompany riders wherever they go, the new WAE Outdoor 04Plus FM pumps out clear and powerful stereo sound, specifically optimized for outdoor conditions - including with wind and other distracting noises in mind. It incorporates a single-unit 2.0 speaker along with a passive decompression driver.
          A thing of beauty
          With its understated yet attractive color scheme and elegant ergonomic design, this new WAE Outdoor wireless speaker is a great-looking accessory that seamlessly blends in with the look of urban riders.
          Get yourself connected
          Thanks to the custom WAE app, the WAE Outdoor 04Plus FM is truly a connected device: your streaming accounts are all plugged right in, preset radio stations are at your fingertips, and you can even set the speaker to power on at a given time and wake you up like an alarm clock!
          Enjoy total freedom with a built-in FM tuner
          The WAE Outdoor 04Plus FM lets you listen to music in any situation thanks to its built-in FM tuner: now that’s freedom! The speaker not only lets you stream music wirelessly from any Bluetooth-enabled device, but also listen to FM radio stations completely on its own in places where you might not want to bring your smartphone along for the ride.
          Providing a whopping 18 hours of battery life in FM radio mode, the WAE Outdoor 04Plus FM is definitely a rider’s best friend!
          Technical specifications
          Physical features
          - Speaker dimensions: 61(H)/ 151(W)/ 61(D) mm
          - Weight: 300 g
          Technical features
          - Bluetooth® 3.0 A2DP wireless technology
          - Total output power: 10 W peak power
          - Single-unit 2.0 speaker + passive decompression driver
          - Frequency response: 130 Hz - 20,000 Hz
          - Built-in rechargeable 3.7 V 1500 mAh Li-ion (lithium-ion) battery
          - Battery life: 10 hours
          - 3.5 mm mini-jack auxiliary line input
          Box contents
          WAE Outdoor 04Plus FM speaker
          Micro-USB to USB cable
          Wrist strap
          User manual
          Minimum configuration
          Compatible with all Bluetooth®-certified devices
        • Product Reviews
