My Cart 0 Item(s)
Shopping Cart is Empty
WAE BTP04 Adventure PACK
Quick Overview
Bluetooth® Portable speaker kit What does your adventure sound like?
IP64-certified wireless speaker: water- and dust-resistant
More details
Availability: In stock
Only 1 left
£39.99
      Move your mouse over image
      More Views
      • WAE BTP04 Adventure PACK
      • Product Description
        Details
        • IP64-certified wireless speaker: water- and dust-resistant
        + complete pack of specially-designed accessories.
        • Perfect for enjoying all of your activities and outdoor adventures with your favorite music! Your music will follow you anywhere, without missing a beat: at the skate park, on the beach after surfing or kiteboarding, on your bike trips, hikes, or while you're skiing!
        • Single-unit stereo speaker.
        • Enjoy audio clarity: two active wideband drivers, plus one passive bass-amplifying driver.
        • Bluetooth® 2.1 + EDR (A2DP) wireless technology.
        • Compatible with Bluetooth® devices: mobile phones and smartphones, tablets, computers (Windows® Vista / 7 / 8, Mac® OS X®).
        • Includes on-the-go charging gear. Speaker provides more than 14 hours of battery life.
        • Rubber end-pieces for enhanced impact resistance, and double protective grille for drivers.
        • Built-in microphone lets you enjoy hands-free calling.
        • On/Off switch and 1/8" / 3.5 mm mini-jack Line input plug.
        • Easily connect WAE* Outdoor BTP04 speakers to one another, using the included USB cable.
        • Bluetooth® receiver mode lets you use the Bluetooth® function with a stereo system (or any other audio system). Listen to the music stored on your Bluetooth® device on your favorite stereo!
        Includes:
        • Secure tether hook, wrist-strap, snap hook.
        • Standard-size screw thread for easy mounting (examples: tripod, suction cup mount, bike mount, etc.).
        Ready for any kind of adventure:
        • Car cigarette-lighter charger: lets you charge your speaker on the drive to get where you're going.
        • Suction cup mount: features a 90 mm suction cup, letting you attach the speaker to any flat, smooth surface (glass, flat panels...).
        • Super-tough bike mount: designed to withstand the vibrations from a motorbike!!
        • Exclusive backpack attachment clip: created by Hercules for extreme use.
        • Both mounts and the backpack attachment clip are perfect for outdoor use, thanks to their water-resistant components.
        • Large carry bag, with two compartments: lets you store the speaker and its basic accessories on one side, and the mounts, backpack attachment clip and car cigarette-lighter charger on the other.
        Technical specifications
        • RMS power: 2 x 2 W RMS
        • Peak power: 8 W
        • Frequency response: 130 Hz - 20,000 Hz
        • Speaker dimensions: 61 (H) / 151 (W) / 61 (D) mm
        • Weight: 280 g
        • Rechargeable 3.7 V 1200 mAh Li-ion (lithium-ion) battery
        • Magnetically-shielded system won’t disturb your surroundings
        • RoHS compliant product
         Box contents
        • Single-unit IP64 Bluetooth® speaker
        • USB charging cable and 1/8" / 3.5 mm male mini-jack Line output connector cable
        • Wrist-strap
        • Snap hook
        • Speaker pouch
        • Bike mount
        • Backpack attachment clip
        • Suction cup mount
        • Carry bag for all items
        • Warranty certificate and User Manual
      • Product Reviews
