My Cart 0 Item(s)
Shopping Cart is Empty
Hercules WAE NEO
Quick Overview
Light up your music !
- Customizable Lighting effects
- Studio sound quality
- Bluetooth® 3.0 A2DP
Bluetooth technology works with iPhone5S®, iPhone5C®, iPhone 5, iPhone 4S, iPhone 4, iPhone 3GS, iPhone 3G, iPhone, iPad (3rd and 4th generation), iPad 2, iPad, iPad mini®, and iPod touch® (2nd through 5th generation).
More details
Availability: In stock
Only 3 left
£69.99
        Hercules WAE NEO
        Move your mouse over image
        More Views
        • Hercules WAE NEO
        • Hercules WAE NEO
        • Hercules WAE NEO
        • Hercules WAE NEO
        • Hercules WAE NEO
        • Hercules WAE NEO
        • Hercules WAE NEO
        • Hercules WAE NEO
        • Hercules WAE NEO
        • Hercules WAE NEO
        • Hercules WAE NEO
        • Hercules WAE NEO
        • Hercules WAE NEO
        • Hercules WAE NEO
        • Product Description
          Details
          Combine the power of sound with the magic of light
          Studio sound quality with full bass enhancement and psycho-acoustic effects thanks to Waves® MaxxAudio plugins, recipient of a Technical GRAMMY Award®:
          • MAXXEQTM Full Spectrum Equalization
          • MAXXBASSTM Psycho-Acoustic Bass Enhancement
          • MAXXVOLUMETM All-in-One Dynamics Conditioning: zero distortion, even at the highest volume levels
          Built-in DSP (Digital Signal Processing)
          Full digital audio processing
          Compensates for lower-quality digital audio encoding
          Dynamic equalizer adapts to the type of music you’re playing
          Ultra-bright, fully customizable, sophisticated lighting effects: the WAE NEO’s RGB LED strips can reproduce up to 16 million colors and pulse in time with your music
          Best-in-class Bluetooth® wireless technology ensures incredible sound quality within a 10-meter range
          Free custom control app for iOS and Android:
          • Easily access your online music services (Spotify®, Deezer®, SoundCloud®)
          • Create hybrid playlists: create playlists using songs from your online music services, as well as songs stored locally on your device
          • Control lighting effects and select your favorite colors
          Easily portable and ultra-convenient, thanks to a built-in rechargeable battery that lets you party all night long!
          Enjoy up to 8 hours of playback with lighting effects on, and 15 hours with lighting effects off
          The most powerful speaker in its category: the WAE NEO delivers 15 W RMS of output power, for great parties anywhere!
          A 3.5 mm mini-jack line input lets you connect an MP3 player or any non-Bluetooth® audio device
          Technical specifications
          Bluetooth® 3.0 A2DP
          NFC
          Ultra-bright RGB LED strips
          Frequency response: 80 Hz - 20,000 Hz
          •Total output power: 15 W RMS
          (30 W peak power)
          •2 wideband drivers
          •Built-in DSP
          Built-in rechargeable lithium-ion battery (7.4 V / 2 Ah)
          Battery life (when powered by the rechargeable battery):
          •8 hours with lighting effects on
          •15 hours with lighting effects off
          International USB power supply: 5 V / 2 A
          Certifications: RoHS, CE, FCC, Bluetooth®-compliant, BQB
          Speaker dimensions and weight: 340 (W) x 140 (D) x 120 (H) mm / 2.05 kg
          Box contents
          Hercules WAE NEO speaker
          International power adapter
          USB cable
          User manual
          Warranty certificate
          Minimum configuration
          Device supporting Bluetooth® 2.1 with A2DP
          App: iOS 4.0 or later / Android 2.2 or later
        • Product Reviews
