My Cart 0 Item(s)
Shopping Cart is Empty
DJ Monitor 5
Quick Overview
Active monitor speakers: experience your mixes the way you’ve been dreaming of! Designed for expert DJs.
  • 2 x 80 W RMS
  • 2 front ports
  • Silk and Kevlar domes
More details
Availability: Out of stock
£249.99
        DJ Monitor 5
        Move your mouse over image
        More Views
        • DJ Monitor 5
        • DJ Monitor 5
        • DJ Monitor 5
        • DJ Monitor 5
        • DJ Monitor 5
        • DJ Monitor 5
        • DJ Monitor 5
        • Product Description
          Details
          Description
          Precision and quality design let you create music mixes on your computer: distinguish all the details of your mixes, and select your choice of sounds
          • Silk-dome tweeters: 30 watts RMS
          • 5-inch woofers with Kevlar membrane: 50 watts RMS
          • Dual ports on front for powerful bass response and effective monitoring
          • Speaker housing crafted of MDF
          • Audio inputs (to connect a computer, DJ gear, mixer):
            • RCA
            • TRS (6.35 mm, balanced input)
            • XLR (balanced input)
          Controls:
          • ON/OFF button on front for easy access
          • LED in ON position
          • Master volume knob on front for more precise control
          • High frequency setting: + or -2 dB
          • Low frequency setting: + or -2 dB
          • Low frequency cutoff: 56 Hz, 80 Hz or 100 Hz
          Power supply selector: 110/120 V, 60 Hz or 220/240 V, 50 Hz
          Technical specifications
          • RMS power: 2 x 80 W RMS
          • Frequency response: 50 Hz - 30,000 Hz
          • Satellite dimensions: 31 (H) x 22.2 (W) x 23.5 (D) cm
          • Right satellite weight: 7 kg
          • Left satellite weight: 7 kg
          • Internal power supply
          • Magnetically shielded satellites won’t disturb your surroundings
          • RoHS compliant product
          Positioning your speaker system
          For optimal positioning of your speakers, you should create an angle of 60° between the two satellites, and between the user and the satellites. It is also important that the listening height be at a level between the woofers and the tweeters.
          Thanks to their performance, you can even position the DJ Monitor 5 speakers lying flat on their side (i.e. horizontally), while maintaining optimal positioning in relation to your position.
          Advanced design
          Thanks to their experience in developing the XPS 2.080 DJ Monitor speakers, which have been widely praised by the DJ community for their excellent precision as well as their accessibility, Hercules’ Audio engineers made use of their cutting-edge equipment (anechoic chamber, test benches) to create this monitoring system, which responds to the needs of the most demanding DJs.
          The development of the DJ Monitor 5 speakers required two years of work in conjunction with professionals in the world of DJing.
          The speakers’ functionalities, the positions of controls, the shapes of the controls, the volume knob’s position markers, and the location of the bass ports on the speakers respond to the needs of the majority of users in terms of ensuring optimal audio rendering during mixing sessions, as well as providing full and powerful audio monitoring.
          Box contents
          • 2 amplified speakers
          • 1 power cord
          • Warranty certificate and user manual
          Minimum configuration
          Windows® 8/7/Vista/XP, Mac®, DVD/CD player, MP3 player, TV set, game console
          Illustrations/Diagrams
        • Product Reviews
