My Cart 0 Item(s)
Shopping Cart is Empty
HDP DJ M 40.1
Quick Overview
Versatile DJ headphones for DJing and leisure use
More details
Availability: In stock
£26.99
      HDP DJ M 40.1
      Move your mouse over image
      More Views
      • HDP DJ M 40.1
      • HDP DJ M 40.1
      • Product Description
        Details
        Description
        DJ headphones for all uses
        • 95 dB at 1 mW sensitivity: strong output level lets you preview tracks in any environment
        • 50 mm diameter drivers: clear playback for strong bass response
        • 20Hz-20kHz: bandwidth covers all audible frequencies, to preview what your speakers can play
        • 60 ohm drivers: low enough impedance for strong output volume on DJ gear, computers and mobile audio players
        Trendy design
        • Large ear-cups
        • Black fabric, matte black housing
        Swivel housing for convenient use
        • Easy 1-ear monitoring
        • Easy folding and mobility
        • Extending arms for both large and small heads
        Efficient sound isolation
        • Large ear pads shield the user’s ears from ambient noise
        • Closed-back ear-cups prevent sound from bleeding out
        Comfortable housing
        • Ear pads’ width and softness isolate the user’s ears
        Technical specifications
        HDP DJ M40.1
        Headphones for DJing & leisure use
        Audio playback
        • 20Hz-20kHz: audible frequencies
        Drivers for DJing
        • 60 ohm impedance
        • Large aperture
        • 1.97"/50 mm driver diameter
        Connectivity
        • 6.5’/2 m cable
        • 1/8"/3.5 mm stereo mini-jack plug
        • 1/4"/6.35 mm stereo jack adapter
        Mechanical specifications
        Ear-cups: Closed-back Circumaural
        2 rotation axes:
        • Earpieces: vertical rotation (180 degrees) for easy 1-ear monitoring
        • Earpiece supports: horizontal rotation (90 degrees) for folding and transport, and to direct the earpiece toward the user’s ear when headphones are worn around the neck
        Connection:
        Single-wire cabling
        Wire attached to left ear-cup
        Box contents
        • DJ headphones
        • 1/8" to 1/4" plug adapter
      • Product Reviews
