My Cart 0 Item(s)
Shopping Cart is Empty
Hercules P32 DJ
Quick Overview
Loop size display Built-in audio Two grids of 16 performance pads
More details
Availability: In stock
£199.99
        Hercules P32 DJ
        Move your mouse over image
        More Views
        • Hercules P32 DJ
        • Hercules P32 DJ
        • Hercules P32 DJ
        • Hercules P32 DJ
        • Hercules P32 DJ
        • Hercules P32 DJ
        • Hercules P32 DJ
        • Product Description
          Details
          Description
          A unique, all-in-one controller at the crossroads of DJing and performance
          With 2 decks, screens displaying the sizes of loops, effects racks, equalizers and more, Hercules P32 DJ is perfectly designed for mixing.
          Add in the two grids of 16 pads, sample packs integrated within DJUCEDTM 40°, the slip and quantize smart functions... and you have a package with all the advantages for performance.
          No compromise - Hercules P32 DJ represents the optimization of 2 worlds of DJing in a single unique controller.
          The thrill of instant creative mixing: Play. Remix. Perform.
          The perfect combination of body and spirit.
          Hercules P32 DJ features 32 ergonomic and responsive pads for precise performance and high-quality feel.
          the intelligence of the DJUCEDTM 40° DJing software lets you keep the rhythm and the structure of tracks intact, no matter what you’re doing.
          All the features to mix and remix are at your fingertips.
          Your only task: focus on the fun of creating.
          Develop your onstage presence
          Being a DJ is much more than just technical skills and creating a playlist: it also involves your ability to put on a show.
          Hercules P32 DJ lets you develop your signature sound, and your visual presentation.
          The combination of pads, dynamic backlighting and sample packs helps you refine your identity as a DJ.
          INCLUDED SOFTWARE
          DJUCEDTM 40°(PC / MAC )
          Complete and intuitive professional DJing software included
          OTHER COMPATIBLE SOFTWARE (NOT INCLUDED)
          The Traktor mapping file is available for download on Hercules’ website
          The Hercules P32 DJ is also compatible with all DJing software open to MIDI mapping, such as
          Virtual DJ, Cross DJ, DJAY, etc. (not included)
          READY FOR FINGER DRUMMING
          Practice Finger Drumming with music production software such as:
          Ableton Live, Garage Band, Bitwig Studio, Melodics, etc.
          Technical specifications
          DJ controller with dual mixing decks
          - Built-in audio (mix + preview outputs)
          - Two grids of 16 performance pads
          Included software:
          DJUCEDTM 40° for Mac®/PC
          Box contents
          Hercules P32 DJ
          Printed Quick Start guide
          USB cable
          Minimum configuration
          System specifications
          DJUCEDTM 40° PC / MAC
          •2 GHz CPU or higher
          •2 GB RAM or more
          •Windows 7 and higher (32 and 64-bit)
          •Mac OS X 10.8 and higher(32 and 64-bit)
          Download DJUCEDTM 40°
          Optional drivers are available for download on Hercules website
          (ASIO and product firmware update)
        • Product Reviews
