My Cart 0 Item(s)
Shopping Cart is Empty
DJControl Air S Party Pack
Bring home the magic of sound and light!
Quick Overview
A unique pack made up of the DJControl Air S Series – a full-featured, intuitive controller – and a LED Party Light USB to light up your parties! Just grab your computer: Hercules will take care of the rest!
More details
Availability: In stock
£129.99
      Move your mouse over image
      More Views
      • DJControl Air S Party Pack
      • Product Description
        Details
        LED Party Light USB
        Stand-alone 3-watt USB rotary RGB LED light
        DJ Controller
        2-deck DJ controller
        2 jog wheels with pressure detection
        Velocity sensitive pads
        Air control: 1 contactless control
        Pressure-detecting jog wheels
        Scratch by pressing on the jog wheels, as naturally
        as with a vinyl record
        Jog wheels also control pitch bend and browsing
        within tracks
        8 pads with velocity detection
        The pads control the sampler, loops and effects
        The inner backlight shows the pads’ activation
        Pads can be set as binary On/Off controls, or gradual controls
        Air control: a contactless sensor lets you control the mix from above, without even touching the device
        DJ Control Air converts the distance to your hand into a MIDI command
        No need to touch the controller: one command of the mix without any physical contact
        Compatible with all light conditions
        Built-in audio outputs for mixing and previewing tracks
        1/8" (3.5 mm) stereo mini-jack output for the mix
        1/4" (6.35 mm) stereo jack output for previewing tracks
        Technical specifications
        USB DJ controller with audio outputs
        2-deck DJ control surface
        • Pressure-detecting jog wheels
        • Contactless control for air mixing
        • 8 progressive pads
        Built-in audio
        • 1/8" (3.5 mm) stereo output for the mix
        • 1/4" (6.35 mm) stereo output for headphone previewing
        DJ software: DJUCED 18°
        • Intuitive, powerful software
        • Mix 2 audio tracks on the fly
        • Save your mix as an audio file
        Mechanical specifications
        Casing: 13.78 x 8.66 x 1.18 "
        35 x 22 x 3 cm
        Jog wheels: 3.94 " / 10 cm diameter
        Weight: 3.1 lbs / 1.4 kg
        USB cable: Attached
        Box contents
        •Hercules DJ Control Air S series
        •Installation CD-ROM (PC/Mac) with PC/Mac DJ software
        •Printed installation guide + online manual
        Minimum configuration
        •Computer with 2 GHz CPU or faster
        •1 GB RAM or more
        •Powered USB port
        •100 MB available hard disk space
        •CD/DVD-ROM drive
        •Internet access
        •Amplified stereo speakers and headphones
        Operating System (32-bit / 64-bit)
        Microsoft Windows® Vista, 7 or 8
        or Mac OS 10.7, 10.8 or 10.9 on Core Duo Mac
      • Product Reviews
        Customer Reviews
        nice Review by Azubuike
        Note
        i love the product (Posted on 09/06/2017)
