My Cart 0 Item(s)
Shopping Cart is Empty
DJControl Air for iPad
Quick Overview
Ready to mix on whatever you want iPad®, Mac and PC
  • Ready for iPad®
  • Coloured rubber  caps
  • Pressure-detecting jog wheels
  • Air control
More details
Availability: In stock
Only 3 left
£109.99
      Move your mouse over image
      More Views
      • DJControl Air for iPad
      • Product Description
        Details
        DJ controller compatible with:
        •iPad with Retina Display & iPad mini thanks to
        •The included Official Apple® Lightning to USB Camera Adapter
        •The Specific Hercules Extra cable for iPad ® Camera adapter  and for power adapter
        •iPad 2 & 3 but extra adapter needed
        •PC and Mac
        Lime-green  rubber caps on faders and rotary buttons
        •Smooth touch for ergonomic use, trendy lime green colour
        •Sharp visual contrast with the black  controller, you see the
        caps position  in low light conditions
        2-deck DJ controller
        •2 jog wheels with pressure detection
        •Velocity sensitive pads
        •Air control: 1 contactless control
        •Scratch by pressing on the jog wheels, as naturally as with a vinyl record
        •Jog wheels also control pitch bend and browsing within tracks
        8 pads with velocity detection
        •The pads control the sampler, loops and effects
        •The inner backlight shows the pads’ activation
        •Pads can be set as binary On/Off controls, or gradual controls
        Air control: a contactless sensor to control the mix from above, without even touching the device
        •DJ Control Air converts the distance to your hand into a MIDI command
        •No need to touch the controller: one command of the mix without any physical contact
        •Compatible with all light conditions
        Built-in audio outputs for mixing and previewing tracks
        •1/8” (3.5 mm) stereo mini-jack output for the mix
        •1/4” (6.35 mm) stereo jack output for previewing tracks
        Technical specifications
        2-deck DJ control surface
        • Contactless control for air mixing
        • 8 progressive pads
        Built-in audio
        • 1/8” (3.5 mm) stereo master out
        • 1/4” (6.35 mm) stereo output for headphone previewing
        DJ software
        • Intuitive, powerful software
        • Mix 2 audio tracks on the fly
        • Save your mix as an audio file
        Mechanical specifications
        Casing:         13”78 x 8”66 x 1”18
                              35 x 22 x 3 cm
        Jog wheels:  3.94 ” / 10 cm diameter
        Weight:         3.1 lbs. / 1.4 kg
        USB cable:     Attached
        Minimum configuration
        iPad with Retina Display (with lightning connector) & iPad mini
        •Lightning to USB Camera Adapter (included)
        •iPad Power Adapter (included with your iPad)
        •iOS 6.1 and above
        iPad 2, 3
        •Camera Connection kit (not included)
        •iPad® Power Adapter
        •iOS 6.1 and above
        PC
        •MS XP, Vista, 7 and 8     32 & 64 bits
        •CPU 1.6GHz and faster / 2GB RAM
         MAC
        •Core Duo CPU
        •OSX 10.6, 10.7 & 10.8     32 & 64bits
        Box contents
        •Hercules DJ Control Air for iPad
        •Installation CD-ROM (PC/Mac) with PC/Mac DJ software
        •Printed installation guide + online manual
        •Extra cable for iPad Camera adapter and for power adapter with setup guide
      • Product Reviews
