My Cart 0 Item(s)
Shopping Cart is Empty
DJ Control Instinct P8 Party Pack
Quick Overview
Your Mix becomes an Interactive light show*
*[translation of the above sentence here: ]
More details
Availability: In stock
Only 1 left
£99.99
        Move your mouse over image
        More Views
        • DJ Control Instinct P8 Party Pack
        • Product Description
          Details
          The ultimate Party Pack, composed of the DJControl Instinct P8 and 8 multicolored wristbands that light up in sync with your mix!
          One DJControl Instinct P8 controller and eight light (LED) wristbands to make your party unforgettable!
          •Incomparable simplicity: simply turn them on, and they instantly sync with the music
          •Multicolored, featuring 16 different colors
          •Sustainable: the wristbands’ batteries can easily be replaced
          The DJControl Instinct P8 is compact, robust and full-featured, with a wide range of features optimized for mixing and remixing :
          •Dual-deck DJ controller
          •8 sample pads with multicolored lighting, allowing better comprehension
          •Loop mode can be triggered temporarily, using the pads, or permanently, using the encoder
          •Effects control and adjustment
          •Dedicated SYNC, Cue, Play/Pause buttons
          •Separate MODES on each deck
          •Touch-sensitive deck and SCRATCH mode
          •3-band equalizer with volume fader and crossfader
          •More functions are accessible using the SHIFT button
          •Built-in sound card with 2 RCA outputs for mixing and a 1.8”/3.5 mm mini-jack stereo output for previewing tracks on headphones
          •Detachable USB cable
          •Easy to install, USB-powered port; no drivers required
          •PC / Mac compatible
          8 LED wristbands light up in sync with your mix!
          Unique, highly intuitive all-in-one controller
          Powerful remix features at your fingertips
          Dual-deck MIDI controller + mixer with built-in sound card
          INCLUDED SOFTWARE
          DJUCED™ 40°(PC | Mac ) : Complete and intuitive professional DJ  software included
          Sample packs by Loopmasters also included!
          OTHER COMPATIBLE SOFTWARE (NOT INCLUDED)
          The Traktor mapping file is available for download on Hercules' website
          The DJControl Instinct P8 is also compatible with all DJ software offering MIDI mapping support, e.g.
          Virtual DJ, Cross DJ, DJAY, etc. (not included)
        • Product Reviews
